block ip phone without extesion mobility
Jean Lofrano
Can I to block the cisco IP phone with a password/PIN without use the extension mobility?
thanks.
Robert Thomas
Level 7
Level 7
You could use FAC codes for outbound calls, but not for internal calls.
Chris Deren
No, there is no security setting that would let you do that.  If you are concerned about phone's ability to make outbound calls you can restrict that with proper CSS, you can also lock down access to Settings, etc.
HTH,
Chris
Robert Thomas
Level 7
Level 7
Great Robert!!
For example: 44560[7-9]XXXXXXX...
Here the password is 4456!!
thanks.
