Community Member
block ip phone without extesion mobility
Can I to block the cisco IP phone with a password/PIN without use the extension mobility?
thanks.
1 ACCEPTED SOLUTION
You could use FAC codes for outbound calls, but not for internal calls.
Hall of Fame Super Silver
No, there is no security setting that would let you do that.  If you are concerned about phone's ability to make outbound calls you can restrict that with proper CSS, you can also lock down access to Settings, etc.
HTH,
Chris
Community Member
Great Robert!!
For example: 44560[7-9]XXXXXXX...
Here the password is 4456!!
thanks.
193
