Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Block Long Distance Transfers
What are the config steps to prevent toll fraud where a user sets his call forward all (transfer) to an long distance number. I don't want to stop all transfers to off-net since users ofter transfer/call forward their main line to a cell phonem which is off net but stil local. Just want to prevent long distance transfers.
Re: Block Long Distance Transfers
Just set the call forward all Calling Search Space to a restrictive scope. They won't even be able to key in a long distance pattern.
Hall of Fame Super Red
Hi Robert,
In most CCM configurations it is recommended to have multiple CSS's (Calling Search Space) that limit access to various calling levels.
For example you might have;
On-Campus CSS - Allows only 4-digit Dialing
Local CSS - Allows 9+7-digit Local Dialing
Long Distance CSS - Allows full 9(0+1)10-digit
You can then apply these same CSS to the Call Forward All CSS to prevent against Toll Fraud abuse. So in your case you might allow either On-Campus or Local CSS against Call Forward All :)
Hope this helps!
Rob
Thanks everyone. I was so focused on the call classification field in the route patterns that I didn't consider the easiest solution that was to change the Foward All CSS. Thanks again. That's the easiest way.
141
