Block Malicious Calls (CCM4.1)
johnson_cheng
Does Callmanager have a feature to block malicious calls,based on the calling number? If the answer is yes, how can I do the settings?
17 Replies 17
If you want to block DNIS, it is easily done from the CallManager:
Create a Route Pattern that matches what DNIS you want to block, then set it to "Block this Pattern".
Yes, that I know. However I want to block an outbound call originating on the H.323 gateway....bypassing the call manager completely.
Yes, you can still do that. You just need to apply the "call-block" to the inbound dial-peer, not your outbound peer:
voice translation-rule 101
rule 1 reject /9xxxxxxxxxx/
voice translation-profile TEST-BLOCK
translate called 101
dial-peer voice 1000 voip
call-block translation-profile incoming TEST-BLOCK
