Community Member
Block Outgoing Numbers
Am using CUCM 6.1 and am trying to set up a translation pattern to stop users dialing 123. The translation pattern looks to be set up however it is not working.
Translation is set so that when dialed 9.1XX is blocked with no error message. But users still can dial through. I don't have a Calling Search Space attached to this route plan though.
Any ideas on how this can be done?
1 REPLY
Re: Block Outgoing Numbers
If it's 123 why don't you try 9.123??
Or try configuring a route pattern and block it at that level
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
111
