05-20-2009 06:45 AM - edited 03-15-2019 06:06 PM
Is there a way to block calls with either no IE display or 'unknown caller'? I'm not sure if it's possible to do this with translation rules at the gateway because there's really no number to match on. I know in CCM I can set the Unknown Caller ID and Text fields to set the calling number and name on these calls. ...but I'm not aware of any ANI-based routing options in CCM.
Any ideas? I searched the forums for this but couldn't find anything other than MCID for some school bomb threats which is not applicable.
thanks,
Will
Solved! Go to Solution.
05-20-2009 07:17 AM
voice translation-profile block
translate calling 100
voice translation-rule 100
rule 1 /^$/ reject
voice-port x/y/z
translation-profile block incoming
Again, if you do this, chances are the customer will have you remove it after a while because too many calls are rejected.
05-20-2009 06:49 AM
Are you using h.323 or mgcp ?
Note however that many valid calls do come without a calling number.
05-20-2009 07:03 AM
h.323
I've got a customer who asked what the possible options are.
05-20-2009 07:17 AM
rule 1 /^$/ reject
voice-port x/y/z
05-20-2009 07:21 AM
Agreed. Some would call that job security. I'm with you -- it's an annoyance.
Anyways... Is there a way to do this at the CCM level?
thanks again,
Will
05-20-2009 07:22 AM
Not sure, but I don't think so.
Please remember to rate useful posts with the scrollbox below.
05-21-2009 04:08 AM
Hi all,
Can we do it if we have an MGCP gateway?
05-21-2009 08:16 AM
No.
