Block the button of volume
Is possible button block of volume in ip phone 6921, researched in internet, I found the option Minimum Ring Volume but no the Maximum or block the button, locking the volume and set fixed volume.
CUCM: 8.6.2.22900-9
Firmware ip phone 6921: SCCP69xx.9-3-3-2-SR1
2 ACCEPTED SOLUTIONS
Use the settings access
Use the settings access option under the device config page for that.
java
if this helps, please rate
www.cisco.com/go/pdi
No
No
java
You need to mention the call
You need to mention the call control agent you use, and version, and not just what you want to achieve.
java
The version of the CUCM is 8
The version of the CUCM is 8.6, the phone this firmware SCCP69xx.9-3-3-2-SR1
java
Don't can I lock only the
Don't can I lock only the option of the volume?
No
No
java
Thank you, more a help.
107
