How to block calls has been discussed hundreds of times before at CSC, and it has nothing to do with the phone model. If you search CSC for the topic, you'll find all the information you need for this.
If you're an end user, you may want to reach your local IT department for this as this requires configuration in the call control agent or the GWs.
java
if this helps, please rate
