Blocking an inbound call
Need to block an inbound call, I'm sure this can be done just need a little help. CM 8.51
2 ACCEPTED SOLUTIONS
Hall of Fame Super Red
Hi Mark,
For H.323 gateways;
These documents were nicely posted up by Java recently;
Call Blocking Configuration Examples
http://www.cisco.com/en/US/customer/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml#con11
Reject Calls
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml#reject
If your Gateways are MGCP this was added in CUCM 8.x
From Dan @ Cisco for MGCP
https://supportforums.cisco.com/docs/DOC-18367
Cheers!
Rob
Please remember to tag your threads and help support "Teachers without Borders"
https://supportforums.cisco.com/community/netpro/idea-center/communityhelpingcommunity
Pls provide more details. Where do you want to block inbound calls i.e. at phone level or at gateway level ? Is any contact center involved ?
GP.
Hi Mark,
For H.323 gateways;
Reject Calls
Cheers!
Rob
There is no contact center involved.  I would prefer to block it at the gateway level, before it even makes it to the phone so that the end user doesnt even have to deal with the call.
GP.
All needs to be done at the Gateway level, we are using all H.323 and SCCP protocols no MGCP at all.  I looked over this
document.  I assume this need to be added to the gateway router with the PRI's.
394
