Community Member
Blocking an inbound number
Hi all,
I have a customer that wants to block a particular number from dialing into the company.
I know you can use h323 to do this but they are currently using MGCP though.
They are upgrading to 7.0 soon and I thought that there was an option in 7.0 where you could block an inbound call with mgcp on the call manager.
is this true?
thanks!
1 REPLY
Re: Blocking an inbound number
AFAIK this hasn't changed on 7.0, still needs to be done on H323 GWs
java
if this helps, please rate
java
www.cisco.com/go/pdi
125
