Blocking an incoming number
Is there a way to block one specific number called into call manager from the PSTN?
Hall of Fame Super Gold
Re: Blocking an incoming number
How you are connect to PSTN ? Type of interface, mgcp, or H.323 ?
And what do you mean, rejecting the call? That can be done only with PRI. All other calls must be answered and then disconnected.
Only if you are using an H.323 GW for your incoming calls:
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K15182736
/Jorge
174
