Blocking Collect Call ISDN
How can I do to block the collect calls on E1 ISDN?
Re: Blocking Collect Call ISDN
Well you can use translation profiles on the GW itself.
If you are using CCM you can use FAC or just CSS/Partitions to avoid those numbers.
Give details of your topology to see exactly what can be done.
//J
I forgot a small great detail. Incoming Collect Calls....!!
Sorry
unless they all come using a known ANI ALL the time there is no way to do such thing
Reject Calls
http://www.cisco.com/en/US/partner/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml#reject
Call Blocking Configuration Examples
http://www.cisco.com/en/US/customer/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml#con11
if they do come all the time using the SAME ANI then you can use the above procedures.
java
if this helps, please rate
java
www.cisco.com/go/pdi
Hall of Fame Super Red
Hi Peterson,
You would normally work with your Telco/Provider to block these type of Collect calls. They have the ability to block these before they ever reach your setup. We went through this process with our Telco a few years ago and it works perfectly!
Hope this helps!
Rob
299
