03-13-2008 08:53 AM - edited 03-15-2019 09:26 AM
We are running CM/Unity 4.2 with IPCC and receiving harassing caller that I am looking to block. What is the easiest way to do this. I am far from a voip system expert, I am learning as I go along. Any help would be greatly appreciated.
03-13-2008 12:33 PM
Are you using H323 or MGCP gateways to route call?
If you are using H323 you can block this at the gateway. MGCP gateways can't block incoming numbers.
Jason
03-13-2008 12:40 PM
we are using MGCP.
A much easier solution I brought up is to just i-divert the offensive calls when the called id shows up, but I cant seem to find where to specify the i-divert. The number that is getting the harassment has no voicemail, this way if they see the caller calling in, they can just dump them to a voicemail box and check it, or we can save the messages in case we want to pursue anything legal.
03-13-2008 12:51 PM
Mark,
Here is a document on I divert you will have to set this softkey up. The document should have the instructions that you need.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_1_3/ccmfeat/fsimmdiv.html
Jason
