Community Member
Blocking incoming calls in CM 6.X?
Does anyone have any experience blocking calls? What else should I do to block these calls?
We are receiving calls from on outside caller to a senior level manaer within my company. The number shows up in CDR and on the caller ID as a 6 digit number. I opened a ticket with TAC to block the incoming call and we made chages to the gateway the calls are coming through. The calls are still making it through.
We are going to be upgrading our CM to 9.x next month.
Any assistance would help.
Everyone's tags (3)
1 REPLY
Right now you can only block calls if you're using H323, the topic has been covered thoroughly at CSC, you just need to search.
Once you're on 9.X, you get to choose to either do it on CUCM, or still in H323.
Voice Translation Rules
http://www.cisco.com/en/US/partner/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
Number Translation using Voice Translation Profiles
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml
https://supportforums.cisco.com/docs/DOC-18367
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
146
