Blocking incoming calls on CM 4.1(3)
mparekh
Level 3
Level 3
Is there anyway I can block a incoming call from a particular number. What would I need to do to prevent incoming calls from 973-xxx-xxxx? Is this possible with CM?
5 Replies 5
Aaron Dhiman
Level 2
Level 2
It is possible if the call comes in on an H.323 Gateway. Not if the GW is MGCP, though.
It is coming over H323...what woud I need to do?
Aaron Dhiman
Level 2
Level 2
jbarcena
Level 9
Level 9
It is not possible to do this with CCM, but as already stated you can do it with your H.323 Gateway, try the following:
Use Translation rules:
config t
voice translation-rule 1
rule 1 reject /#/
rule 2 reject /#/
*where # is the number that you wish to block.
config t
voice translation-profile BLOCK_NUMBER
translate incoming 1
Assign this translation profile to the incoming dial-peer that you are using.
Hope that helps, if it does please rate the post.
//Jorge
Hi, in the example above, it should be:
translate calling 1
