Blocking incoming numbers on voice gateway CUCM 5
Hi there all
Can someone please inform of the best method to block unwanted spam calls hitting one of our DDI numbers. I have done this some time back by using the rule reject /xxxx/ and the applying a profile to the PSTN dial peer. However we are using MGCP so peers not configured. Am I missing something really silly? Is it possible within CUCM
Re: Blocking incoming numbers on voice gateway CUCM 5
I have researched this and found that the easy method would be to create translation pattern. However, as I cannot filter on the ANI only the DNIS then this would mean all calls to the DDI would would have to be routed to a CSS containing nothing.
Any other ideas most welcome
Simon
Hall of Fame Super Red
Sorry for the huge delay Rob......I always value your input.....thanks
Simon
Hey Simon,
No worries! As they say "better late than never" my friend
Cheers!
Rob
229
