Blocking off-net to off-net transfers (toll-fraud prevention)
Hi Guys,
I Would like know if is possible implemeting toll-fraud prevention to specific IP Phone or this functionallity is enable or disable only in Global Mode. My Customer have the CallManager 5.1.3
Wilson
2 ACCEPTED SOLUTIONS
Re: Blocking off-net to off-net transfers (toll-fraud prevention
The setting is global, you cannot set this per phone.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
The setting is the same in 8.X, it's under the
Clusterwide Parameters (Feature - General)
Section
java
java
java
java
Hi Javalenc,
This feature is not supported in any version more recent? for exemplo 8.x?
Wilson
Section
java
java
339
