Blocking outgoing call based on Calling Number
hi,
we have a central call manager and up to 10 SRST sites connected.
I would like to block Some  users from dialling outside number starting with 901xxxxx .But due to some techincal reasons i can not do this from our call manager,so it has to be from the site router.
My requirement is, i need to block users whose extensions are 123X from dialling outside number 9 01 xxxxxxxx,using translation rule or any other method,from the voice gateway (h323)router.
can anybody tell me how to solve this...
regards.
Renypmukku.
1 REPLY
Hall of Fame Super Gold
You can use answer-address to match an incming dial-peer then apply COR or a translaton-rule.
the technique is the same as:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00801c0a88.shtml
263
