Blocking-Pattern Route List
tka
Hi all,
Is it necessary to set the Route List, Route Group and Gateway to dummy RL, RG and Gateways , in a Blocking pattern configuration ?
I understand that you need to block a pattern from your users
It is only by creating this pattern and mark the check box [block this pattern]
wish this be helpful
a RL or a gateway are mandatory elements when creating a route pattern.
you cannot only create it with the pattern and block this pattern
dummy/real RL/GW are necessary to be selected to create the route pattern and block calls
java
if this helps, please rate
java
