Community Member
Blocking specific number from the PSTN to our 2811
I'm running h323 between CCM and my 2811, I would like to block a specific caller-id when he try to call us I want to block him.
I think a dialpeer would be fine on the 2811 but i'm not exacly sure how it is working with call block.
did you guys ever did that before, do you have a configuration exemple : )
thanks
1 ACCEPTED SOLUTION
VIP Super Bronze
Re: Blocking specific number from the PSTN to our 2811
Philippe,
On this forum, we have a habit of appreciating the great work memebers do. Next time dont forget to rate useful posts. Paolo I have helped rate this for you..Keep on rocking!
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hall of Fame Super Gold
For up to 10 numbers, use voice translation-profile and rule with the reject option under voice port.
For more, build specialized incoming DP with partial match via answer-address, apply differentiated voice translation-profile and rule.
Usually after that approach, insisting callers begin to hide their number, to which there is no remedy.
Community Member
thanks ! it's working fine !
VIP Super Bronze
Philippe,
114
