Blue Gate ISDN GSM gateway with ISDN BRI configuration
Hi to all!
Here is the problem:
At customer site we have old PBX system that we replacing with CUCM+C2911 E1 trunk to PSTN. Customer also have two GSM gateways connected to PBX. It is Blue Gate ISDN:
http://www.telsyco.cz/assets/photos/TELSYCO%20BlueGate%20ISDN%20manual%20en.pdf
We have no access to this GSM gateway and our task is to replace PBX with Cisco without additional configuring that Blue Gate ISDN GSM gateway.
When I connect Blue Gate to ISDN BRI interface, I can receive incoming calls but outgoing calls not passing. I tried with different outgoing number patterns, but nothing works.
Here is error with csim test:
csim: called number = 0992414876, loop count = 1 ping count = 0
csim err csimDisconnected recvd DISC cid(422)
csim: loop = 1, failed = 1
csim: call attempted = 1, setup failed = 1, tone failed = 0
So, I tried to intercept outgoing calls from old PBX to Blue Gate - I connect BRI 0/2/0 to Blue Gate and BRI 0/2/1 to PBX, but interface to PBX is not going up.
Here is status:
ISDN BRI0/2/0 interface
        ******* Network side configuration *******
        dsl 8, interface ISDN Switchtype = basic-net3
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 8 CCBs = 0
    The Free Channel Mask:  0x80000003
ISDN BRI0/2/1 interface
        dsl 9, interface ISDN Switchtype = basic-net3
    Layer 1 Status:
        DEACTIVATED
    Layer 2 Status:
        Layer 2 NOT Activated
    Layer 3 Status:
    Active dsl 9 CCBs = 0
    Total Allocated ISDN CCBs = 0
Config is:
interface BRI0/2/0
no ip address
isdn switch-type basic-net3
isdn protocol-emulate network
isdn layer1-emulate network
isdn incoming-voice voice
isdn static-tei 0
isdn skipsend-idverify
interface BRI0/2/1
no ip address
So I have two questions:
1. what could be reason that outgoing calls not going through Blue Gate but incoming does?
2. what ISDN BRI configuration should be for connecting to old PBX (MD110)?
Thanks  in advance,
Sinisa.
Everyone's tags (3)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Blue Gate ISDN GSM gateway with ISDN BRI configuration
Can you try:
voice-port 0/2/0
compand-type a-law
bearer-cap speech
Take "debug isdn q931" with "term mon".
Hi Paolo,
here is debug- first incoming call that is OK:
2w5d: ISDN BR0/2/0 Q931: RX <- SETUP pd = 8  callref = 0x76
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x81
                Preferred, B1
        Progress Ind i = 0x8081 - Call not end-to-end ISDN, may have in-band info
        Calling Party Number i = 0x0180, '0038599241xxxx'    <<< I hide last 4 digits
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0x80, '600'   <<< 600 is my internal extension
                Plan:Unknown, Type:Unknown
        High Layer Compat i = 0x9181
        Sending Complete
2w5d: ISDN BR0/2/0 Q931: TX -> CALL_PROC pd = 8  callref = 0xF6
        Channel ID i = 0x89
                Exclusive, B1
2w5d: ISDN BR0/2/0 Q931: TX -> ALERTING pd = 8  callref = 0xF6
Jan 23 21:14:14 HR: %ISDN-6-CONNECT: Interface BRI0/2/0:1 is now connected to 0038599241xxxx N/A
2w5d: ISDN BR0/2/0 Q931: TX -> CONNECT pd = 8  callref = 0xF6
        Channel ID i = 0x89
                Exclusive, B1
2w5d: ISDN BR0/2/0 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x76
Jan 23 21:14:17 HR: %ISDN-6-DISCONNECT: Interface BRI0/2/0:1  disconnected from 0038599241xxx , call lasted 3 seconds
2w5d: ISDN BR0/2/0 Q931: TX -> DISCONNECT pd = 8  callref = 0xF6
        Cause i = 0x8290 - Normal call clearing
2w5d: ISDN BR0/2/0 Q931: RX <- RELEASE pd = 8  callref = 0x76
        Cause i = 0x8090 - Normal call clearing
2w5d: ISDN BR0/2/0 Q931: TX -> RELEASE_COMP pd = 8  callref = 0xF6
then outgoing call:
2w5d: ISDN BR0/2/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Calling num 600
2w5d: ISDN BR0/2/0 Q931: Sending SETUP  callref = 0x0046 callID = 0x80AA switch = basic-net3 interface = Network
2w5d: ISDN BR0/2/0 Q931: TX -> SETUP pd = 8  callref = 0x46
        Bearer Capability i = 0x8090A2
                Standard = CCITT
        Channel ID i = 0x89
                Exclusive, B1
        Calling Party Number i = 0x0081, '600'
        Called Party Number i = 0x80, '099241xxxx'  <<< I hide last 4 digits here
2w5d: ISDN BR0/2/0 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xC6
        Cause i = 0x80D8 - Incompatible destination
then also try outgoing call...but I dial full international number 00385xxxxxx:
2w5d: ISDN BR0/2/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Calling num xxx600  <<< I hide first 3 digits
2w5d: ISDN BR0/2/0 Q931: Sending SETUP  callref = 0x0047 callID = 0x80AB switch = basic-net3 interface = Network
2w5d: ISDN BR0/2/0 Q931: TX -> SETUP pd = 8  callref = 0x47
                Standard = CCITT
        Channel ID i = 0x89
                Exclusive, B1
        Calling Party Number i = 0x0081, 'xxx600'   <<<< I hide first 3 digits
        Called Party Number i = 0x80, '0038599241xxxx'
2w5d: ISDN BR0/2/0 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xC7
So as I can see...in second attempt GSM gateway puts 3 digits on internal extension as calling number...which is then real PSTN outside number, but not on GSM side... So I suppose that there is something with translation patterns that I shold play? I tried...but have no idea what to try next.
S.
Are you using H.323 or MGCP ?
2911 router with this ISDN BRI card is configured as H323 gateway on CUCM for all calls, if you asked that.
Try:
interface br0/2/0
isdn outgoing-voice info-transfer-capability  3.1kHz
If not that, have to look in the number format accepted by the other device.
Nope...doesn't work...same error.
What do you mean by "look in the number format accepted by other device"?
Somehow the called number is not right, you have to find what the other device expects.
today I managed to connect to GSM gateway via serial port. Nothing special there...I also speak with man which was configuring that gateway few years ago, and conclusion is that there is no special requirements for called or calling number.
It seams like there is some problem with BRI configuration on my side.
Can you try:
voice-port 0/2/0
compand-type a-law
bearer-cap speech
EXCELLENT!!!
Thank you Paolo wery much!!
It works!
Best regards,
Sinisa.
I did not noticed the u-law companding before.
Thanks for the nice rating and good luck!
1668
