Bogen TPU-15A Paging Callmanger Express
Has anyone setup a Bogen with Callmanager Express? If so, did you use a FXO or FXS card to connect. Did you have to use a TAM B? Any help would be greatly appreciated.
I currently have it plugged into a FXO port with the other end connected to the TIP and RING. The speaker is then connected to 70V connection.
1 ACCEPTED SOLUTION
Re: Bogen TPU-15A Paging Callmanger Express
A loopstart Fxo trunk (default) should work.
http://www.bogen.com/support/productcatalog/pdfs/catalog.pdf
They do say in this link that interface a telephone trunk to the amplifier requires a trunk interface adapter like TAMB.
What model from Bogen are you using?
It's a TPU-15A with a SPT15A loud speaker.
Sounds good. I have also opened a support case with Bogen and will update if I find out any new information.
536
