Bootable ISO download
Hi all.  Im trying to get a bootable CUCM download from the download site.  I have downloaded 6.1.3, but it appears to not be a bootable iso.  I need one to reload a server completely, then upgrade it to 7.1.3.  I will be getting the proper licenses from Cisco (already ordered), but I really need to do a fresh install at this point.  Anyone know what version I can download to get a bootable image and put it on a DVD myself, then do the upgrade to 7.1.3?  Any help appreciated.
Re: Bootable ISO download
You won't be about to download a bootable ISO from CCO.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
The files already say they're not bootable before you download them
UCSInstall_UCOS_6.1.3.1000-16.sgn.iso_part1of2
Release Date: 15/Dec/2008
Cisco Unified Communications Manager 6.1(3) part 1 of 2 (non-bootable) - For upgrade from 6.1(1) or 6.1(2)
Size: 1254111.00 KB  (1284209664 bytes)
ALL of them, if you need fresh install media you'll never find one on CCO.
You need to order it because it's physical media what you need.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
938
