BOQ for CUCM 8.5 with Bundled CCX
Hi there,
I have devised a BOQ based on CUCM 8.5 with MCS server; and for using 5 CCX user I have added additional MCS server and appliance entitlement for CCX server. Below is the BOQ.
Server software:
Product
Description
Quantity
CUCM-USR-LIC
Top Level Sku For User License
LIC-CUCM-USR-A
Unified Communications Manager Enhanced Single User-Under 1K
50
UCM-7816-85
Unified Communications Manager 8.5 Server Software
CCX-85-CMBUNDLE-K9
CCX 8.5 5 Seat CCX ENH CM Bundle - AVAILABLE ONLY FOR NEW CM
CUCM-PAK
Include PAK Auto-expanding PAK for CUCM
CUCM-USR
Include PAK Auto-expanding User for CUCM
300
UCM-7816-85-KIT
CUCM 8.5 Media Kit
UCM-7816-NODE
CUCM 7816 Node
Server for CUCM:
MCS7816I5-K9-CMD2
Unified CM 8.5 7816-I5 Appliance, 0 Seats
Server for CCX
MCS7816I5-K9-CXA1
CCX 8.5 7816-I5 Appliance 1x X3430 CPU, 4GB RAM, 1x250 HDD
Appliance Entitlement for CCX server
L-CCX-85-CMBLDLIC=
CCX 8.5 CCX CM Bundle Appliance Entitlement, PAK eDelivery
And 5 IP communicator license
IPCOMM86-LIC
Cisco IP Communicator 8.6 license
I would like to know if I have not missed out anything in the above and BOQ is correct, this is basically a small requirement for call center where they only require to use 5 enhanced users.
I have also heard that CISCO is now supporting more UCS server instead of MCS. Need advice on how to Map above requirement on UCS. Please recommend. I think it will save one MCS server if we got with UCS route.
Best regards,
Faisal Qadri
Blue
HI
If you are Cisco partner. Please open case at cisco.com/go/ph. PH team is equiped with verifying BOQ.
Ronak patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
VIP Super Bronze
Yes you can use UCS. For this size install you could use a C200M2 chassis:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/solution_overview_c22-597556.html
The rest of the guidelines are posted to the DocWiki:
http://docwiki.cisco.com/wiki/Unified_Communications_Virtualization
The problems that stand out at frist glance:
  • You have no ESW or UCSS
  • You have no public space or analog port license. No lobby/meeting room phones or fax machines?
  • You have no router for PSTN connectivity or DSPfarm functionality.
  • You are missing the DVDs for CCX (CCX-85-SRVRS-MEDIA)
  • You are missing the OS license for CCX (L-CCX-85-BDL-ADDON)
1804
