both voice and data vlan does not work on the same port
I have a home lab with the following setup:
vlan 5->data
vlan 10->voice
CME Router Cisco 1760 has been configured as a DHCP server to assign IP for both for data and voice vlan.
CME Router1760 configuration:
int f0/0.10
ip address 192.168.10.1
encap trunk dot1q 10
int f0/0.5
ip address 192.168.5.1
encap trunk dot1q 5
Switch3524 configuration
int f0/1
switchport access vlan 5
switchport voice vlan 10
int f0/2
switchport access vlan 10
int f0/24
switchport mode trunk
switchport trunk encap dot1q
switchport trunk allowed vlan 1,5,10
int vlan 1
no ip address
int vlan 5
ip address 192.168.5.4 255.255.255.0
I get request time out when I ping 192.168.5.4
IP phone works in VLAN 10 when I plug it to f0/2.
Computer gets IP address from data Vlan when I plug into f0/1.
My question is how can I make both data and vocie vlan work at the same port.I also tried with setting the trunk port in f0/1 but it does not work.
I will appreciate any thoughts....
Thanks in advance.
Bronze
Re: both voice and data vlan does not work on the same port
Hi friend, as a suggest, I have this configuration in all my switches and it work good:
interface FastEthernet0/1
switchport access vlan 460
switchport mode access
switchport voice vlan 461
mls qos trust dscp
spanning-tree portfast
Also make sure that the voice vlan is UP (show interface vlan X)
hth
David
Bronze
Hi Arjun,
if you're going to use this method in your lab try configuring f0/1 like this
int f0/1
switchport trunk native vlan 5
that should get you up and running,
regards,
Paul
418
