Community Member
Brazil E1 R2
We are setting up a 10 channel E1 R2 in Brasilia. Its currently working perfectly with a PBX, we are moving it to CME with 2811
We are in the testing stage, I am testing it remotely from Europe which isnt ideal.
Currently, the E1 comes up and inbound calls ring ok -  after a delay. However once you pickup the phone all you hear is a loud tone and no voice.
Any help appreciated - please see configuration / debug below and attached debug file.
Im not sure what to change.
James
2811 / ADV Ipservices / 12.4 (24)T8 / VWIC-2MFT-E1=
Current Configuration
controller E1 0/0/0
 framing NO-CRC4
 clock source line primary
 ds0-group 1 timeslots 1-10 type r2-digital r2-non-compelled ani
 cas-custom 1
  country brazil
  metering
  double-answer
  category 2
  answer-signal group-b 1
voice-port 0/0/0:1
 no echo-cancel enable
 cptone BR
sho voice call summary
PORT           CODEC     VAD VTSP STATE            VPM STATE
0/0/0:1.1       -          -  -                     R2_Q421_IDLE
0/0/0:1.2       -          -  -                     R2_Q421_IDLE
0/0/0:1.3       -          -  -                     R2_Q421_IDLE
0/0/0:1.4       -          -  -                     R2_Q421_IDLE
0/0/0:1.5       -          -  -                     R2_Q421_IDLE
0/0/0:1.6       -          -  -                     R2_Q421_IDLE
0/0/0:1.7       -          -  -                     R2_Q421_IDLE
0/0/0:1.8       -          -  -                     R2_Q421_IDLE
0/0/0:1.9       -          -  -                     R2_Q421_IDLE
0/0/0:1.10      -          -  -                     R2_Q421_IDLE
0/1/0         -          -  -                     FXSLS_PARK
0/1/1         -          -  -                     FXSLS_PARK
 sho voice port summary
                                           IN       OUT
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
0/0/0:1         01  r2-digital  up    dorm idle     idle     n
0/0/0:1         02  r2-digital  up    dorm idle     idle     n
0/0/0:1         03  r2-digital  up    dorm idle     idle     n
0/0/0:1         04  r2-digital  up    dorm idle     idle     n
0/0/0:1         05  r2-digital  up    dorm idle     idle     n
0/0/0:1         06  r2-digital  up    dorm idle     idle     n
0/0/0:1         07  r2-digital  up    dorm idle     idle     n
0/0/0:1         08  r2-digital  up    dorm idle     idle     n
0/0/0:1         09  r2-digital  up    dorm idle     idle     n
0/0/0:1         10  r2-digital  up    dorm idle     idle     n
0/1/0           --  fxs-ls      up    up   off-hook idle     y
0/1/1           --  fxs-ls      up    up   off-hook idle     y
sho voice port
R2 Slot is 0, Subslot is 0, Sub-unit is 0, Port is 1
 Type of VoicePort is R2
 Operation State is DORMANT
 Administrative State is UP
 No Interface Down Failure
 Description is not set
 Noise Regeneration is enabled
 Non Linear Processing is enabled
 Non Linear Mute is disabled
 Non Linear Threshold is -21 dB
 Music On Hold Threshold is Set to -38 dBm
 In Gain is Set to 0 dB
 Out Attenuation is Set to 0 dB
 Echo Cancellation is disabled
 Echo Cancellation NLP mute is disabled
 Echo Cancellation NLP threshold is -21 dB
 Echo Cancel Coverage is set to 128 ms
 Echo Cancel worst case ERL is set to 6 dB
 Playout-delay Mode is set to adaptive
 Playout-delay Nominal is set to 60 ms
 Playout-delay Maximum is set to 1000 ms
 Playout-delay Minimum mode is set to default, value 40 ms
 Playout-delay Fax is set to 300 ms
 Connection Mode is normal
 Connection Number is not set
 Initial Time Out is set to 15 s
 Interdigit Time Out is set to 10 s
 Call Disconnect Time Out is set to 60 s
 Ringing Time Out is set to 180 s
 Wait Release Time Out is set to 30 s
 Companding Type is A-law
 Rx  A bit no conditioning set
 Rx  B bit no conditioning set
 Rx  C bit no conditioning set
 Rx  D bit no conditioning set
 Tx  A bit no conditioning set
 Tx  B bit no conditioning set
 Tx  C bit no conditioning set
 Tx  D bit no conditioning set
 Region Tone is set for BR
 Station name None, Station number None
 Translation profile (Incoming):
 Translation profile (Outgoing):
 Voice card specific Info Follows:
 Line Signalling Type is r2-digital
 Register Signalling Type is r2-non-compelled
 Country setting is brazil
 Answer Signal is group-b 1
 Category is set to 2
 NC Congestion is set to 4
 KA is set to 0
 KD is set to 0
 Caller Digits is set to 1
 Request Category is set to 0
 End of DNIS is set to False
 DNIS Digits min is 0 and max is 0
 ANI Digits min is 0 and max is 0
 Group A Callerid End is set to False
 Metering is on
 Release Ack is set to False
 Unused ABCD Bits Mask configured: 0 0 0 0
 Inverting ABCD Bits Mask configured: 0 0 0 0
 Debounce Time is set to 40ms
 Release Guard Time is set to 2000ms
 Seizure Ack Time is set to 100ms
 Answer Guard Time is set to 0ms
 ANI Timeout is set to 0s
 DS0 channel specific status info:
                                      IN      OUT
PORT            CH  SIG-TYPE    OPER STATUS   STATUS    TIP     RING
0/0/0:1          01  r2-digital  dorm idle     idle
0/0/0:1          02  r2-digital  dorm idle     idle
0/0/0:1          03  r2-digital  dorm idle     idle
0/0/0:1          04  r2-digital  dorm idle     idle
0/0/0:1          05  r2-digital  dorm idle     idle
0/0/0:1          06  r2-digital  dorm idle     idle
0/0/0:1          07  r2-digital  dorm idle     idle
0/0/0:1          08  r2-digital  dorm idle     idle
0/0/0:1          09  r2-digital  dorm idle     idle
0/0/0:1          10  r2-digital  dorm idle     idle
show controllers e1
E1 0/0/0 is up.
  Applique type is Channelized E1 - balanced
  No alarms detected.
  alarm-trigger is not set
  Version info Firmware: 20090113, FPGA: 20, spm_count = 0
  Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line Primary.
  Data in current interval (436 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Total Data (last 24 hours)
     842 Line Code Violations, 2754 Path Code Violations,
     11 Slip Secs, 2 Fr Loss Secs, 23 Line Err Secs, 0 Degraded Mins,
     1 Errored Secs, 0 Bursty Err Secs, 24 Severely Err Secs, 30815 Unavail Secs
Brasilia-2811-VOIP#sho voice register all
VOICE REGISTER GLOBAL
CONFIG [Version=7.1]
  Version 7.1
  Mode is srst
  Max-pool is 0
  Max-dn is 0
  Outbound-proxy is enabled and will use global configured value
  timeout interdigit 0
  network-locale[0] US    (This is the default network locale for this box)
  network-locale[1] US
  network-locale[2] US
  network-locale[3] US
  network-locale[4] US
  user-locale[0] US    (This is the default user locale for this box)
  user-locale[1] US
  user-locale[2] US
  user-locale[3] US
  user-locale[4] US
VOICE REGISTER DN
VOICE REGISTER POOL
1 REPLY
Community Member
I got this working but the
I got this working but the box is offline - once its back - I'll post the working config here for others.
120
