10-09-2013 02:44 AM - edited 03-16-2019 07:47 PM
Hii,
I want to activate BRI for a video Conference ( Athera Vega X5 ), any information/steps will be very helpful.
Solved! Go to Solution.
01-19-2014 11:02 PM
Hi Gabriel,
You do not need an extra license for activating BRI card. Did u try connecting straight cable ?
can u share the show version and sh license feature /show license[for ISR G2] all from the router?
regds,
aman
01-19-2014 11:14 PM
Feature name Enforcement Evaluation Subscription Enabled RightToUse
ipbasek9 no no no yes no
securityk9 yes yes no no yes
uck9 yes yes no yes yes
datak9 yes yes no no yes
gatekeeper yes yes no no yes
SSL_VPN yes yes no no yes
ios-ips-update yes yes yes no yes
SNASw yes yes no no yes
hseck9 yes no no no no
cme-srst yes yes no no yes
WAAS_Express yes yes no no yes
UCVideo yes yes no no yes
01-19-2014 11:20 PM
Hi Gabriel,
there seems to be physical layer connectivity between NT1 [ISDN Terminal Device] and VIC-BRI card.try connecting straight cable.As per the snapshot , u are using cross-over cable.
can u share the config of router ?
regds,
aman
01-20-2014 12:30 AM
1 | White orange | 1 | White blue |
2 | Orange | 2 | blue |
3 | White green | 3 | White green |
4 | blue | 4 | White orange |
5 | White blue | 5 | orange |
6 | green | 6 | green |
7 | White brown | 7 | White brown |
8 | brown | 8 | brown |
01-20-2014 01:19 AM
! Last configuration change at 15:20:26 UTC Fri Jan 17 2014
version 15.2
service password-encryption
hostname test
boot-start-marker
boot-end-marker
card type e1 0 0
logging buffered 51200 warnings
no aaa new-model
network-clock-participate wic 0
network-clock-participate wic 2
network-clock-select 1 E1 0/0/0
ip cef
ip dhcp excluded-address xxxxx
ip dhcp pool ccp-pool
import all
network xxxxx xxxxxxx
default-router xxxx
lease 0 2
no ipv6 cef
isdn switch-type primary-net5
crypto pki trustpoint TP-self-signed-xxxxxx
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-xxxxxxx
revocation-check none
rsakeypair TP-self-signed-xxxxxx
crypto pki certificate chain TP-self-signed-xxxxxxxx
certificate self-signed 01 nvram:IOS-Self-Sig#1.cer
voice-card 0
license udi pid xxxxxxx1/K9 sn xxxxxxx
hw-module pvdm 0/0
hw-module sm 1
username admin privilege 15 secret 4 xxxxxxxxxxxxxxxxxxxxxxxxxxxx2
redundancy
controller E1 0/0/0
pri-group timeslots 1-31 service mgcp
controller E1 0/0/1
controller E1 0/0/2
controller E1 0/0/3
pri-group timeslots 1-10,16 service mgcp
no ip rcmd domain-lookup
ip rcmd rsh-enable
ip rcmd remote-host admin xxxxx root enable
ip rcmd remote-host routeradmin xxxx admin
ip ssh version 2
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address x.x.x.x x.x.x.x
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface BRI0/2/0
no ip address
isdn switch-type basic-net3
isdn tei-negotiation first-call
isdn layer1-emulate network
isdn incoming-voice voice
isdn bind-l3 ccm-manager service mgcp
line-power
interface BRI0/2/1
no ip address
line-power
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 x.x.x.x
snmp-server community xxxxxxxx
snmp-server enable traps entity-sensor threshold
01-20-2014 01:57 AM
Hi Gabriel,
config seems to be OK.
Is Layer1 Status still showing Deactivated? If yes,please try changing the cable.
Did u ever try changing NT1 also?
regds,
aman
01-22-2014 01:19 AM
Hii GUys,
I change the cable, make a new one but the same. Maybe I have to bay a new cable because i don't understand what is wrong.....
Omerpal are you sure is the right patch ???
01-22-2014 01:43 AM
Hi Gabriel,
Cable could be one of the cause but u have already tried changing it .
Did u ever try changing NT1 ?
regds,
aman
01-22-2014 01:54 AM
No i don't tray NT1.
01-27-2014 05:18 AM
Hiii.
I find some information, on the router I have a ISDN BRI S/T 1 (2nd generation two port BRI voice interface daughtercard on Slot 0 SubSlot 2 )
and I find I need a ISDN BRI 0 NT1 in order to work with my video Conference Aethra Vega X5.
Maybe I need to buy a NT1 to put between my router and the videoconference, I change 10 times the cable but still not working.
I am not sure what card I need for Aethra Vega X5??????????
Th for help:)
http://www.cisco.com/en/US/prod/collateral/modules/ps5949/data_sheet_c78_439537.pdf
http://hw-server.com/constrc/atm_prog_lpt_shift/programmer.html
01-27-2014 05:40 AM
Hi Gabriel ,
If your ISDN service provider is giving U-interface , then, u do not need NT-1 , it can directly plug into device with U-interface.
If your router has S/T interfcae , then , u need NT1 for interface conversion.
regds,
aman
01-27-2014 06:27 AM
I have 2921 with 3 E1 lines and I have ISDN BRI S/T 1 and from Port 0 I want to connect directly to the Video Conference.
02-17-2014 09:44 AM
Stil working on this issues.
show interfaces BRI 0/2/0
BRI0/2/0 is up, line protocol is down (spoofing)
Hardware is Voice NT or TE BRI
MTU 1500 bytes, BW 64 Kbit/sec, DLY 20000 usec,
Encapsulation VOICE, loopback not set
Keepalive set (10 sec)
Last input 4w3d, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
3 packets input, 19 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
16 packets output, 123 bytes, 0 underruns
0 output errors, 0 collisions, 21 interface resets
0 unknown protocol drops
29 carrier transitions
show version
3 Gigabit Ethernet interfaces
104 Serial interfaces
2 ISDN Basic Rate interfaces
1 terminal line
4 Channelized E1/PRI ports
show controller bri 0/2/0
BRI unit 9:
layer 1 operating in LT-S mode.
Layer 1 is DEACTIVATED. (ISDN L1 State G1)
D Channel Information:
idb at 0x21B6BD70, driver data structure at 0x3C832C08
Infineon Chip Version 0x1
Infineon Registers:
Int. Status Register [ISTA]=0x00, Aux. Int. [AUXI]=0x00
D-channel: Int. Status Reg: [ISTAD]=0x00, Status. Reg: [STARD]=0x40
Mode Reg: [TR_MODE]=0x03
Transceiver Reg: [TR_CONF0]=0x00
Test mode Reg: [TMD]=0x00
IOM Control Reg: [IOM_CR]=0x08
Status Register [STAR]=0x40, Mode Register [MODED]=0xCA
Serial Data Strobe Control Reg: [SDS1_CR]=0x00, [SDS2_CR]=0x00
RX Buffer Descriptor is at 0x3C832F24, Buffer size 1524
pak=0x22BE0038 data_ptr=0xE25E654 partial_size=0x0
