BRI configuration
Hi Guys,
I really need some help with the configuration of 3 ISDN BRI circuits in Europe.I have a 2800 series with 3 bri`s in the back which the site will use for incoming and outgoing calls.I have never setup BRI`s before only E1`s so not sure where to even begin.If someone could please point me in the right direction or perhaps give me an example of what my config should look like it would be much appreciated...thanks in advance!!!
Re: BRI configuration
Hi There also have the same problem. Using a 2800 with 4 BRI ports connecting to Premicells to allow outgoing calls to the different Mobile operators in South Africa. If you come right please give me shout, if I find something relevant will let you know
Shaun
Hall of Fame Super Gold
You can use the configuration I suggested.
The most important thing you've to find is if your premicell devices require router to be network or user side, and if static tei is required. Possibly they can work both ways, just configure router accordingly.
After that, you troubleshoot with "debug isdn q931" and "term mon".
Ar the lines in hunt-group ? If so the config will be likely:
int bri 0/0/0
isdn switch-type basic-net3
isdn static-tei 0
trunk-group bri
isdn overlap-receiving <--- not always required, but doesn't hurt
ised sending-complete <-- same as above
int bri 0/0/1
dial-peer voice 111 pots
destination-pattern 0....T
trunkgroup bri
Note in many countries you can also eliminate the prefix digits (0 or 9) for external calls. Just make you extension all begin with an unused digit. users like that very much because it's "like calling from home".
Hi Brilliant !!
Just what i needed. I can now see the calls come in on debug q931 but when i added the trunk group bri to my pots dial peer the calls got rejected.Once i removed it,the call comes in as normal but i then get a type of dial tone when calling in ...appreciate your help,been on this for ages now ....
There are incoming and outgoing DPs. the trunkgroup is for outgoing ones and you need it there, remove any port command you ad first.
For incoming, normally you have
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
However to ring the destination phone, the called number must match extension. This is either with a translation-profile, or dialplan pattern under telephony-service. The details varies with each installation and country.
This is what my current voice config looks like :
aaa session-id common
clock timezone GMT 0
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-participate wic 2
trunk group bri
voice-card 0
no dspfarm
interface LoopbackXX
description VIRTUAL | LOOPBACK | Router Management | -
ip address X.X.X.X 255.255.255.255
no ip redirects
ip route-cache flow
load-interval 30
h323-gateway voip bind srcaddr X.X.X.X
interface BRI0/0/0
description SHUTDOWN |
bandwidth 64
no ip address
no ip redirects
no ip proxy-arp
ip route-cache flow
isdn incoming-voice voice
isdn sending-complete
isdn static-tei 0
trunk-group bri
interface BRI0/0/1
bandwidth 64
no ip address
no ip redirects
no ip proxy-arp
ip route-cache flow
isdn static-tei 0
trunk-group bri
interface BRI0/1/0
bandwidth 1
no ip address
no ip redirects
no ip proxy-arp
ip route-cache flow
shutdown
isdn point-to-point-setup
interface BRI0/1/1
bandwidth 64
no ip address
no ip redirects
no ip proxy-arp
ip route-cache flow
isdn static-tei 0
trunk-group bri
interface BRI0/2/0
bandwidth 1
no ip address
no ip redirects
no ip proxy-arp
ip route-cache flow
interface BRI0/2/1
bandwidth 1
no ip address
no ip redirects
no ip proxy-arp
ip route-cache flow
interface Serial0/3/0
bandwidth 1
no ip address
no ip redirects
no ip proxy-arp
ip route-cache flow
load-interval 30
shutdown
clock rate 2000000
interface Serial0/3/1
bandwidth 1
no ip address
no ip redirects
no ip proxy-arp
ip route-cache flow
load-interval 30
shutdown
clock rate 2000000
interface Dialer1
description WAN | BRI
no ip address
no ip redirects
no ip proxy-arp
encapsulation ppp
ip route-cache flow
no ip mroute-cache
load-interval 30
dialer pool 1
dialer idle-timeout 180
dialer-group 1
no keepalive
no cdp enable
ppp multilink
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/2/0
voice-port 0/2/1
dial-peer voice 50 voip
destination-pattern 5446835..
session target ipv4:134.32.8.130
incoming called-number .T
dial-peer voice 30 pots
destination-pattern .T
incoming called-number 5446835..
direct-inward-dial
forward-digits all
dial-peer voice 51 voip
destination-pattern 35..
codec g711ulaw
At the moment if i call in from my mobile i can see the call come in but i am still getting a dial tone on my mobile.I need to translate the incoming 9 digits the carrier is presenting to four digits.All the call manager config is done and i have one DN setup for testin.
compare the "incoming called-number" on DP 30 with what you receive from telco as "debug isdn q931", they have to match. Or just use ".". Else you get dialtone.
The DP thing take a little to be understood, after you'll be OK.
Calling Party Number i = 0x0183, '3391721202'
Plan:ISDN, Type:Unknown
Called Party Number i = 0xA1, '544683500'
Plan:ISDN, Type:National
They seem to match from the output.do i not need to do anything on the voiceports or create some translation rules.
Yes they match. The call should be getting to the CM, it seems strange that it gives dialtone but I cannot exclude that. Check with "debug voip dialpeer".
There is no match on debug dial-peer and the output from the sh DP voice shows operation state & outbound state as down :
peer type = voice, information type = voice,
description = `',
tag = 30, destination-pattern = `.T',
answer-address = `', preference=0,
CLID Restriction = None
CLID Network Number = `'
CLID Second Number sent
CLID Override RDNIS = disabled,
source carrier-id = `', target carrier-id = `',
source trunk-group-label = `', target trunk-group-label = `',
numbering Type = `unknown'
group = 30, Admin state is up, Operation state is down,
Outbound state is down,
incoming called-number = `5446835..', connections/maximum = 0/unlimited,
DTMF Relay = disabled,
URI classes:
Destination =
huntstop = disabled,
in bound application associated: 'DEFAULT'
out bound application associated: ''
dnis-map =
permission :both
incoming COR list:maximum capability
outgoing COR list:minimum requirement
Translation profile (Incoming):
Translation profile (Outgoing):
incoming call blocking:
translation-profile = `'
disconnect-cause = `no-service'
advertise 0x40 capacity_update_timer 25 addrFamily 4 oldAddrFamily 4
type = pots, prefix = `',
forward-digits all
session-target = `', voice-port = `',
direct-inward-dial = enabled,
digit_strip = enabled,
register E.164 number with H323 GK and/or SIP Registrar = TRUE
fax rate = system, payload size = 20 bytes
supported-language =
Admin state is up and that's what matters.
Oper state is down due to no active calls. Outbound is down due to lack of destination-pattern and port, however being this an incoming DP, that doesn't matter.
Do you have any translation rule ? Try "incoming called-number ." as suggested above.
The incoming called number is added to the dial peers.I dont have any translation rules setup.
This is doing my head in :-)
I added the port numbers to the dial-peers and am now able to receive calls but unable to make any.
480
