BRI disconnect TOne
Hi all,
REcently i have tried to configure Supervisory disconnect under a BRI card (using the Voice-port creted virtuall) but the command is no longer listed like in the FXO configuration.
SO if i don't have my CPTONE country listed and there is no supervisory configuration were i can't aplly custom cptone so how can i disconnect call when the Calling party hang up the phone!!
Thanks for helping me out
2 ACCEPTED SOLUTIONS
Hall of Fame Super Gold
Re: BRI disconnect TOne
Just to verify, can you send the debug isdn q931 trace ?
However when the person on the IP phone hears a disconnect tone, he/she should hang up and that's it.
With ISDN, you don't.
Thanks for the appreciation and good luck!
ISDN doesn't need tones for disconnect. A Q.931 message specifies when the remote has disconnected. Consequently no supervisory disconnect configuration is necessary.
Note: In some countries, for an incoming call, it is not possible to actually terminate the call until the caller has disconnected.
Hi Bevilacqua how is going my friend :)
Indeed when i use the debug isdn Q931 i saw the disconnect message but the phone still use the Busy tone and it only disconnect after 30 sec
So any ideas how i can discreate this timeouts
Which phone are you talking about ?
I meant that we i receive a call from the (PSTN using the BRI) and someone answer the phone and when the calling (the one who call from the PSTN) hang up i still listen in my IP Phone to the disconnect tone then the Busy after that it disconnect bu it takes so much time (about 30 secs)
thanks for help :) u just confirm to me that i don't even need any kind of supervisory disconnect
175
