BRI in morroco
Hi everybody,
I have a big problem with a router Cisco 2911 and BRI from Maroc Telecom.
I have this status for my BRI :
ISDN BRI0/0/0 interface
        dsl 0, interface ISDN Switchtype = basic-net3
        L2 Protocol = Q.921 0x0000  L3 Protocol(s) = CCM MANAGER 0x0003
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 78, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0x80000003
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 1. Layer 3 output may not apply
ISDN BRI0/0/1 interface
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
    Layer 3 Status:
    Active dsl 1 CCBs = 0
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 4. Layer 3 output may not apply
When i make an incoming call, i can't see the call incoming on my gateway with the command "debug isdn q931" and i have an ocupated ringtone on my phone.
My gateway have a "isdn switch-type basic-net3" on on my cucm, the gateway have the global isdn switch-type "EURO"
This configuration is operational on all my other place in france.
Do you think my problem is on the operator or on my configuration ?
1 REPLY
VIP Gold
If you are not getting
If you are not getting anything at debug isdn q931 that means calls are not hitting to router itself. So it seems to be  service provider issue.
I hope you had enabled "term mon" after above debug command.
Suresh
74
