Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
BRI interface not showing in show voice port summary
I have a 2901 with a VIC3-2FXS/DID and a VIC2-2FXO cards.
These two cards work ok.
I bougth a WIC-1B-S/T-V3  to replace the FXO.
There are no voice ports showing for the BRI card after i installed it.
What am i doing wrong or what do i need to enable the voice ports for BRI?
Thank you,
laszlo
1 ACCEPTED SOLUTION
Green
Your WIC-1B-S/T-V3 card is a DATA WAN element it does NOT support voice.
You will need to consider a VIC2-2BRI-NT/TE
For voice working
Alex
Regards, Alex. Please rate useful posts.
1 REPLY
Green
For voice working
Alex
276
