BRI MGCP issue with Callmanager 6
have tried to set up an MGCP gateway with 2 x VIC2-2BRI-NT/TE cards.
all is ok, except when I try to configure the individual ports.
I am unable to select a protocol from the BRI Protocl drop down box within the Interface Information section. All that is available is -- Not Selected --
I am looking to select BRI-NET3 but it is not there!!!
any ideas?
N.
1 ACCEPTED SOLUTION
Re: BRI MGCP issue with Callmanager 6
.9901 means next release, i just checked the bug and it has been updated
Fixed-In
6.1(2.9901.59)
7.0(0.39700.127)
7.0(0.66666.1)
7.0(0.66666.2)
7.0(1.11000.2)
7.1(0.98999.7)
6.1(2.1122.1)
last ES available at CCO is
UCSInstall_UCOS_ES_6.1.2.1112-2.sgn.iso
so you'll have to log a TAC case to get the ES you need.
java
if this helps, please rate
java
www.cisco.com/go/pdi
maybe this bug??
CSCsq38457
Unable to select the BRI protocol for the BRI interface in CUCM
Symptom:
Conditions:
Issue is observed for c2801 configured for MGCP control.
There is no option to add the BRI protocol for the BRI interface in CUCM.
This is observed for CCM 6.1.1 and 6.1.2. Issue was not observed for CCM version 4.2 and 5.1.3
Workaround:
None
Fixed-In
6.1(2.9901.59)
7.0(0.39700.127)
java
java
My version is 6.1.2.1000-13 and it is indeed a 2801 ISR.
To upgrade to 6.1(2.9901.59), is this a reinstall?
N.
Fixed-In
6.1(2.9901.59)
7.0(0.39700.127)
7.0(0.66666.1)
7.0(0.66666.2)
7.0(1.11000.2)
7.1(0.98999.7)
6.1(2.1122.1)
java
java
The Prerequisites here might clarify some things as well
http://www.cisco.com/en/US/docs/ios/voice/cminterop/configuration/guide/
vc_mgcp_bri_sig_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1
057714
240
