BRI on C881-V-K9
I cannot find in the data sheet of C881-V that the BRI interface could be used as ISDN network side function or not.
Can I set these parameters?
interface BRIx
 isdn switch-type basic-net3
 isdn protocol-emulate network
 isdn layer1-emulate network
Laszlo
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hi Laszlo.On 880 Datasheet,
Hi Laszlo.
On 880 Datasheet, you'll find that you can use that parameter
http://www.cisco.com/c/en/us/products/collateral/routers/887-integrated-services-router-isr/data_sheet_c78_459542.html
Voice port-specific features
FXS: FXS provides battery polarity reversal detection and initiation for disconnect supervision and far-end answer supervision.
ISDN BRI network side and phantom power: The BRI port provides the ability to connect a private branch exchange (PBX) or private automatic branch exchange (PABX) configured as user side directly to the router. It also provides phantom power to accommodate equipment that requires it.
LED indicators show voice-processing resources and port status.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Laszlo.
Carlo
Dear Carlo,Thank you for your
Dear Carlo,
Thank you for your help.
I need this feature.
Laszlo
119
