BRI outgoing DID
We have a VIC2 - BRI-NT/TE card installed and configured with CME. Incoming and outgoing calls are working fine. Also, incoming calls with DID are working.
Now the customer wishes to have DID for outgoing calls, meaning that extension 101 when reaches the PSTN network obtains the primary line as caller ID of the ISDN supplier and when extension 102 reaches the PSTN network obtains the seconday line as caller ID.
I would appreciate helping me in accomplishing the above.
Below is the ISDN router's configuration so far:
interface BRI0/0/0
no ip address
isdn switch-type basic-net3
isdn tei-negotiation first-call
isdn point-to-point-setup
isdn incoming-voice voice
voice-port 0/0/0
compand-type a-law
dial-peer voice 2121 pots
destination-pattern XXXXX......
port 0/0/0
dial-peer voice 1121 pots
incoming called-number .
direct-inward-dial
port 0/0/0
num-exp XXXXX1 2341
num-exp XXXXX2 2342
Thank you
123
