Community Member
Bridge Upgrade for MCS-7825 series from 6.1.x to 8.6.x
    I have 2 questions here.
     1) Anyone has successfully upgrade from 6.1.x to 8.6.x directly using the bridge upgrade approach?
      2) I have the below older MCS servers available for the above upgrade but Cisco recommended 4GB RAM and 160Gb harddisk. Is it possible still to     use the servers for a lab test upgrade?
MCS-7825-I2-RC1
HW Only, MCS-7825-I2 with 2GB RAM, Dual 80GB SATA HD
CAB-ACU
Power Cord UK
MCS-7825-I1-CC1
HW Only MCS-7825-I1 with 2GB RAM and 80GB HD
CAB-ACU
Power Cord UK
CCBU-WIN2K-ENG
Windows 2000 Server - English
Cheers,
Brandon
Re: Bridge Upgrade for MCS-7825 series from 6.1.x to 8.6.x
None of those servers are compatible with cucm. Review the hw compatibility list to see which servers are supported.
java
if this helps, please rate
www.cisco.com/go/pdi
Community Member
Hi Javalenc,     My apology for the mistake. I have MCS-7825I-3.0-IPC1 with only 1 GB RAM and 80GB HD. Is this sufficient hardware to do a small Proof of Concept testing to ensure that the upgrade from 6.1 to 8.6 is ok? http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
No, there's no way to install CUCM with just 1 GB in RAM.
java
www.cisco.com/go/pdihelpdesk
java
330
