BRIs Keep Flapping UP/DOWN 15 SEC MGCP - HELP!
Hi All,
Just running a test CUCM manager on VMware hence no tac case, both my BRI interfaces keep flapping every 15 seconds due to MGCP.
Could be the call manager, but its harder to post debugs from...
Calls all work fine cos its only down .1 secs
Any ideas on what to check??? THANKS!
HOR-VGW#show mgcp statistics
UDP pkts rx 489892, tx 489939
Unrecognized rx pkts 0, MGCP message parsing errors 0
Duplicate MGCP ack tx 0, Invalid versions count 0
CreateConn rx 287, successful 287, failed 0
DeleteConn rx 287, successful 287, failed 0
ModifyConn rx 557, successful 557, failed 0
DeleteConn tx 0, successful 0, failed 0
NotifyRequest rx 183, successful 183, failed 0
AuditConnection rx 0, successful 0, failed 0
AuditEndpoint rx 46, successful 42, failed 4
RestartInProgress tx 24, successful 24, failed 0
Notify tx 488508, successful 488508, failed 0
ACK tx 1356, NACK tx 4
ACK rx 488532, NACK rx 0
Collisions: Passive 0, Active 0
interface BRI0/0/0
description OnRamp2
no ip address
isdn switch-type basic-net3
isdn point-to-point-setup
isdn incoming-voice voice
isdn bind-l3 ccm-manager service mgcp
isdn static-tei 0
voice-port 0/0/0
compand-type a-law
cptone AU
bearer-cap Speech
ccm-manager fallback-mgcp
ccm-manager mgcp
mgcp
mgcp call-agent 203.xx.12.53 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp ip qos dscp cs3 signaling
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax rate 14400
no mgcp fax t38 ecm
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/1
mgcp bind media source-interface GigabitEthernet0/1
mgcp profile default
Oct 1 05:55:10.219: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/0/1, TEI 0 changed to down
Oct 1 05:55:10.231: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/0/1, TEI 0 changed to up
Oct 1 05:55:10.587: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/0/0, TEI 0 changed to down
Oct 1 05:55:10.603: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/0/0, TEI 0 changed to up
Oct 1 05:55:25.223: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/0/1, TEI 0 changed to down
Oct 1 05:55:25.251: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/0/1, TEI 0 changed to up
Oct 1 05:55:25.591: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/0/0, TEI 0 changed to down
Oct 1 05:55:25.607: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/0/0, TEI 0 changed to up
Oct 1 05:55:40.231: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/0/1, TEI 0 changed to down
Oct 1 05:55:40.247: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/0/1, TEI 0 changed to up
Oct 1 05:55:40.599: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/0/0, TEI 0 changed to down
Oct 1 05:55:40.615: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0/0/0, TEI 0 changed to up
Silver
Re: BRIs Keep Flapping UP/DOWN 15 SEC MGCP - HELP!
check the layer 1 issue, check the cables if possible replace them with the new ones.
Do a shut and no shut on the BRI Interface.
Reload on the router if possible.
Thanks, but not layer 1, when MGCP is disabled services are 100%. router has been reloaded. Also rebuilt server on physical instead of VMware.
I believe it has something to do with MGCP timers but im not up to speed on those... any other ideas?
Cheers
I have exactly the same problem. Did you find something?
Apparently it's not a problem for the calls, but it's strange...
Thank you.
Yorick
Actually I havent fixed it, just a test system so im not too concerned. I think it affects a few calls as the BRI is down about 1% of the time, so not often but occassionally you might need to hit redial.
Which country are you in?
I am also having this issue - Did anyone resolve this?
Hall of Fame Super Gold
I recommned you use H.323 for BRI. MGCP is too buggy to be reliable.
Yes, unfortunately I never resolved it, just migrated to H.323 which doesnt report any errors. If you need a config just ask
Yes please James - Can you forward me an alternate H323 config - Thanks
This is a cut down version of what I have, but its a lab environment only so you will need to fix up the dial peers etc
547
