Brooktrout Fax Card - need help
We have a customer with Brooktrout TR114 + 4PC card , which has 2 inbound and 2 outbound lines. Two outbound lines works fine with regular FXS line connected to VG224 with MGCP but inbound doesn't. Looks like it is little different for inbound on these cards because same outbound setup did not work, we need help from our experts we have vg224, FXO ports and 2 port DID FXS card what is the best way to connect inbound on this card so they can receive inbound faxes?
Thanks for your help.
Everyone's tags (4)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Wink-start would imply you had to use an E&M interface , however with a regular FXO, try "immediate start" on the card side. The FXO will outpulse some digits to let the card know to who the fax has to go.
Re: Brooktrout Fax Card - need help
If you have a TR114+uP4C that means the two incoming ports are meant to be connected to analog DID circuits.
That is, you have to connect them to an FXO port , not FXS. There is no possibility whatsoever of having an analog DID interface (also called FXS/DID) to work connected to another FXS.
Thanks Paolo for quick response. Is there anything I need to do special on the config side on FXO ports because they were saying it could be winkstart?
Paolo, Thanks for helping us here. How would you configure an FXO port for immediate start? under signal type we have option for cama, LS or GS ?
I meant, on the TR114 card. Leave defaults on Cisco side.
Paolo, Okay we have changed that to "immediate" on the fax server now, what do I need on the router I have a H323 Gw to my FXO router (since fax DID's are coming through my PRI which is on anothe Gw router) I have this DP configured and voice-port config like this anything else need to be configured
voice-port 0/2/3
timeouts call-disconnect 3
timing hookflash-out 50
dial-peer voice 100 pots
destination-pattern 49..
port 0/2/3
forward-digits 0
prefix 49
Do I need any other dial-peers on voice port config on the FXO port.?
If you want the cisco to always dial 49, that seems fine.
Thanks for the nice rating and good luck!
859
