Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Brows user directory from another CUCM cluster
In my scenario there are two CUCM cluster and requiremnt is to interlock user directory between these two clusters.  Users across the cluster should be able to search each other including theri own cluster user.
Not sure other then common AD integration if there is any way to acheive this.  Will global directory as a service pointing to another CUCM cluster will work??
SKhare
Thanks Saurabh
2 ACCEPTED SOLUTIONS
Hall of Fame Super Silver
If you are on version 9+ then you can have AD and non-AD users, so you have import local users from the other cluster. Alternatively you can develop your own directory and use it for corporate directory or purchase one from many 3rd party options.
HTH, please rate all useful posts!
Chris
No, you need to present the service as XML, so you would need to develop and host it on a web server, there are plenty of good example on previous similar questions here with links to Cisco SDK.
Chris
Easiest way would be to create AD directory integrations for both sides.
Are you already integrated to AD?
What version of CUCM are you using?
Chris
Hey Chris,
two different AD integrated to each cluster and cross AD integration is not an option here.
regards
SKhare
Thanks Saurabh
Chris
Hey Chris,
I wanted to avoid AD and Manual addition. Is it possible to add global directory as service and modify url pointing to another cluster. will this work?
SKhare
Thanks Saurabh
Chris
Hello Chris,
Demand is just to see other side users in theit contact list. So alternatly i am trying one simple option. I have imported users from other cluster and trying to add them via bulk admin tool. Now it gives error user can not be added as LDAP sync is  enabled.  Is this possible we remove LDAY sync for sometime and upload user via bulk.
Saurabh
Thanks Saurabh
SKhare,
You can achieve this (and much more) with 2Ring PHONE SERVICES, www.2Ring.com/newjuice. There is also a free trial available.
Michal (2Ring)
OK !!,
I got a solution here.  I can add local users to CUCM without removing LDAP sync,  usiing BAT tool i created user and defined password and pin . But it gived error to define it in file ot use default credential policy for Password and default.
PIN. After assigning that BAT upload was successful and AD users can see local users in phone directory.
Skhare
Thanks Saurabh
391
