Bug CSCsv36782
afischer1
Hello
I have identified the listed bug in our CUCM 4.2(3)sr4a, the work around for the bug is to ignore the issue.
Does anyone know if there is a fix for this bug?
Jaime Valencia
According to the bug notes it will be fixed in the next BARS version but there is no ETA, currently as you can see in the status is still opened but has been postponed. Right now there is no fix.
java
if this helps, please rate
java
