Build CNF Files for CallManager 7.1.3
hi,
Does anybody know the impact if we set this service parameter in CallManager 7.1.3 : Build CNF Files =  Build All     and
  Enable Caching of Constant and Bin Files at Startup = False  ?
We have to do troubleshooting to remove the cache of TFTP server by running above serv parameter.
-Anyone have used it before and know what is the drawback or impact to running phones config and loads?
- What is reason if by default those command Set to True and None by Cisco?
  • IP Telephony
1 REPLY
VIP Super Bronze
You can click on the service parameter name to get help on it. Usually the help explains the consiquence of your choice.
I haven't seen the Build CNF one before but disabling mem cache of TFTP is only going to reduce performance. The idea is that it puts the CNF files/firmware and such into memory to avoid every TFTP operation hitting the disk. That leaves disk I/O free for things like database sequential writes.
Normally the way you force the TFTP cache to clear is to just restart the service. I have not encountered a valid reason to disable mem cache.
Please remember to rate helpful responses and identify helpful or correct answers.
118
