Community Member
Build Speed Dial Lists
CUCM 7.1 Linux Servers.
This process works fine, but is very time consuming for users. Anybody know if
there is a way for users to import via an excel document?
Can you upload from an excel format instead of keying every contact one by one ?
1 REPLY
Re: Build Speed Dial Lists
If you mean via CCMuser, no.
The only ways are CCMuser, CCMadmin or BAT. BAT involves exporting all details and then reimporting with the speed dials.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
160
