Community Member
built-in bridge support on Cisco 7961
                  What is the minimum firmware version needed for built-in bridge on 7961?
I don't think there's a minimum firmware version to support the built in bridge, that phone model I believe has always had support for the built in bridge.  Is there a particular feature you're interested in using the built in bridge for because that likely has a CUCM minimal version requirement?
Community Member
We are running CUCM 8.6, and use DMS for call recording purposes, we have noticed that 7961s on 8.X firmware do not seem to produce the DMS streams for call recording. When we upgrade FW to 9-1-3 call recording works ok. The question is what is the min FW version needed?
300
