01-07-2009 08:40 AM - edited 03-15-2019 03:22 PM
Looking for some ideas. What is the most efficient way to add 300 phones to my CM cluster? Is the BAT tool the fastest way to do it? Has anyone used TAPS? One concern is, we usually deploy ext mobility which isn't dependant on the phone. This particular deployment we will be giving everyone a hard phone. What is the best way to do this?
Solved! Go to Solution.
01-07-2009 09:02 AM
i'd say go with BAT if you need to configure almost all the specs from the phones. if you only need the basic features you might consider auto-registration, just a thought
java
if this helps, please rate
01-07-2009 09:50 AM
Hi Daniel,
You are most correct. We usually do up stickers and an excel spreadsheet up ahead of time with the pertinant info. As you scan the phones into XL pop a label on the IP Phone box at the same time. The spreadsheet can then be used to copy/paste the info into BAT. Works Great!
Hope this helps!
Rob
01-07-2009 09:02 AM
java
01-07-2009 09:10 AM
Hi Daniel,
Just add a note to the good tips from my friend Java. One major consideration these days is that you will require a seperate MCS box to build TAPS on if you are using any CUCM Version past 4.x. You used to be able to build the IPCC/TAPS on box with Windows based CCM's, but this is no longer the case with Linux based versions.
A good Barcode scanner and BAT is an excellent way to go!
Cheers!
Rob
01-07-2009 09:16 AM
This site is currently on CM 4.2.3. So my big consideration is when I scan in the phone and assign the user settings to the phone that we keep track on which phone is going on which desk... Correct? Thanks again for all of your help.
01-07-2009 09:50 AM
Hi Daniel,
Hope this helps!
Rob
01-07-2009 10:29 AM
Perfect. That was the info I needed.
