Bulk adding speed dial
Brad Martin
Level 3
Level 3
Our company wants to push out a speed dial (new conference bridge number) for all existing Cisco phones. Without exporting the phones, editing the .csv and importing them back, does anyone know of a way to do this? (Two clusters: 6.1.2 & 4.1.3).
testeven
Hi!
There's an enhancement request opened for this:
CSCsb01778 BAT: Update phone template does not allow bulk speed dial changes
Sadly, you'll need to export the phone, edit the .csv and import them back.
Teresa.
Regards, Tere. If you find this post helpful, please rate! :)
gogasca
Level 10
Level 10
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K59169030
In 4.1.3 you need to use the method described in 6.x you can use Override existing config option
