Silver
Bulk admin of CSS and partitions
Is there a way to work directly with the database to add/remove partitions to CSSs in bulk the way IPMA does when you install it?
1 REPLY
Bronze
Re: Bulk admin of CSS and partitions
I dont suggest remove partitions and CSS from database (SQL) directly, it will break the link or even wrose corrupt the database.
The best way to do, it goes to admin web page, then select which partition and CSS you want to delete and click the "Dependency Records", then you can find out which "route pattern, route list, phone, etc" use those partition and CSS you want to delete.
Hopefully help...
Ken
124
