Community Member
Bulk admin on cuc for call handlers
I have to add a number of call handlers to allowing dialing by extension through the AA since not all users will be getting a voicemail box. Is there a bulk add option for call handlers, i didnt see this option available.
Hall of Fame Super Silver
Re: Bulk admin on cuc for call handlers
You don't need call handlers for those users, simply on the AA call handler check the checkbox to allow transfers for non user extensions.
Chris
Community Member
Hi Chris,
I tried this and the message received was that the extension didnt exist. When i tried adding the call handler with the extension it worked.
I am using the opening greeting and edited the standard greeting to allow this. I have attached the screenshot.
Please check the "Allow transfers to numbers not associated with users or call handlers" check box.
Chris
Community Member
Sorry...I did check that option and that didnt work. The message i am getting is "you cannot be transfered to this number".
Any thoughts why this may be happening. the restrictions table was also verified and didnt block this number.
Did you check it on all greetings? perhaps you are not hitting the standard greeting.
Chris
130
