Bulk change default background image in phones
I have a CUCM 8.0 with 100 phones and I want to change the background of all the phones. I know how to do it going one by one (settings, user preferences, change image) but I want to know if there is any way to change the default image in all the phones at same time. And if I can delete all images except the logo that I want to use.
Thanks a lot
David
Everyone's tags (4)
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi David,
The default Logo is built-into the phone firmware so it cannot be removed. There
is no native Bulk provisioning of images within CUCM so you have to look at 3rd
party software or other methods
From one of my faves, Bill Bell @ CNC;
http://www.netcraftsmen.net/resources/blogs/pushbackgroundtoipphone.html?blogger=William+Bell
This great doc (check Aarons post towards the bottom of the thread;
https://supportforums.cisco.com/docs/DOC-11493#comment-10040
Here is one of the 3rd party products
http://variphy.com/products/
Cheers!
Rob
Blue
See if phone designer helps you .
I have not used it but you can push wallpaper remotely using this feature. It is worth of try...
http://www.cisco.com/en/US/docs/voice_ip_comm/cupa/phone_designer/7.1/english/install/guide/PD1chapter.html
Ronak Patel
Please rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
I have downloaded the program, and load one phone, but when I try to preview the image in the phone, appears the error "Unable to contact server" (It's a translation from spanish, so I don't know if the error is exactly it in teh english version).
Says that I have to verify if I'm running CUCM version 6 or higher (yes), if the phone personalization is enabled (yes), if the server is active (yes) and if the firmware is ver. 8.4.1 or higher, but I can't find the firmware version in the phone with that numbers, only a SCCP45.9-0-3S. Where can I find the firmware os verify if it's correct?
Hi David,
Cheers!
Rob
Silver
Here is an excellent blog, with an entry on this topic, created by one of
our own NetPros:
Posted by WebUser JanMark Francisco
I'm trying the script and it works fine
Thanks a lot for your help
the written link (http://www.netcraftsmen.net/resources/blogs/pushbackgroundtoipphone.html?blogger=William+Bell
) is not working.
Can anybody provide me the tool to change via buld the background image at the ip phones.
Many thanks.
BR
Michael
6744
