Bulk change of display activity settings for 7945/7965.
Hi All,
Does anybody know if there is any way to make a bulk change of Display Activity settings for large number of 7945 and 7965 phones?
Thanks.
Re: Bulk change of display activity settings for 7945/7965.
Yes, using the Bulk Administration Tool (BAT) you can accomplish this task.  Go to Bulk Administs>Phones>Update Phones>Query.  You can also run this task using a custom file if you prefer.  If using the query method, add a search for device type that contains 7945.
Click on Find and then click on Next (if you have phones listed).  If phones aren't listed, check your query.  Ensure you are using "OR" when adding multiple filters to the "Find" clause.
In the Update Phones screen, scroll down until you see Product Specific Configuration Layout.  You will find display settings here.  Modify accordingly and proceed with scheduling and executing the bulk job.  You will need to reset phones for the parameters to take affect.
HTH.
Bill
Please remember to rate helpful posts.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Yes, it is there indeed! I have checked there before but I did not see
it for some reason!!! Thanks a lot for pointing it to me!
No problem.
176
