Bulk change VG224 lines
     Is there a way to bulk change VG224 lines?  I would like to extend No Answer Ring Durration for about 400 lines, but I can't seem to pull them up in Bulk Administration.  I am using CUCM 8.0.
  • IP Telephony
Everyone's tags (3)
3 ACCEPTED SOLUTIONS
If you can't do it via BAT, then you'd need to look at using the SQL interface. You can do almost anything via this: Including trashing your CUCM DB
GTG
Please rate all helpful posts.
I don't use BAT, so I can't help there. For bulk work, I tend to use the SQL console interface:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cli_ref/8_6_1/cli_ref_861.html#wp39876
GTG
No. But I do have the 600-page data dictionary PDF on my desktop . (I do a fair bit of writing custom CUCM apps) The database has a fair amount of protection within in (strong referential integrity, query throttling, etc) But it won't stop you running a DELETE query where you've missed off the WHERE clause . Oh, and there's no transaction support to help you either. (well, not that's exposed to us mere mortals...)
Providing you're sensible, and test on your dev CUCM, it's not too bad.
GTG
GTG
That's interesting.  My understanding is that CUCM these days uses Informix.  With respect to BAT, can you detail what would be involved?
GTG
Wow, that's actually pretty interesting.  There it is; running SQL statements on the CLI.  If this "run sql " command allows for editing tables and entries, it sounds like it can cause more trouble than is worth.  Have you had any problems in your shop as a result of using this method?
GTG
Oh, I see where you're coming from (helps explain how you would recommend making database changes directly via CLI).  No, this is definitely not a practical method for day to day things (I do some work in MySQL, so I understand what you're saying.)  Yes, I would like to avoid a situation whereby I can accidentally blow away an entire table by forgetting a clause after a long day of staring at a screen.
However, I was not aware of this direct manipulation of data.  Fascinating.  I can't use this approach but I'm glad you mentioned it
Gordon,
     One question - I've not worked with any databases outside of MySQL, but it sounds like other RDBMs are able to handle standard SQL queries, correct?  That sounds really handy since you can write one set of queries and make it portable between multiple platforms, no?
Sorry, don't understand what you're saying/asking.
GTG
Hall of Fame Super Red
Hi Shikamarunara,
Wow! Gordon has given you some great insights here (as usual +5 "G" )
If you don't want to go that route and blow up the dB like I would likely do
Have you tried BAT>Phones>Add/Update Lines>Query if you have anything common
you can search on like Device Pool for these VG's you would be good to go.
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
"May your heart always be joyful And may your song always be sung May you stay forever young " - Dylan
519
