09-11-2008 06:21 PM - edited 03-15-2019 01:13 PM
I am in the process of migrating phones from 4.1 to 6.1, as I move over phones I delete phones from 4.1, create on 6.1, then setup a route pattern that goes across the Intercluster Trunk however what is happening is the DN's dont completely remove themselves from the 4.1 Database. When it is a small amount of phone it is not a problem so I run a Route Plan Report and manually delete. However the number of phones that I am moving is growing larger and wondering if there was a slick way to remove DN's that are no longer attached to a Phone. I know in 6.1 there is a cool way to Bulk Delete but I assume if there is a workaround for Bulk Deleting in CM 4.1 it might be some SQL Query. Anyone have any ideas.
Solved! Go to Solution.
09-12-2008 05:06 AM
of course there is!
look at the drop down menu, unassigned DNs is there as an option
java
if this helps, please rate
09-12-2008 03:55 AM
are you removing the DNs from the unassigned DNs from the route plan report???
they don't completely delete until you remove them from unassigned DNs
java
09-12-2008 05:04 AM
Yes I am using the route plan report but in CM 4.1 there is no option to differentiate between DN's that are unassigned and ones that are. So I have to go hunt and peck. So I was looking maybe for some SQL Query to look for any DN's that are not assigned to phones/devices or any other cool trick.
09-12-2008 05:06 AM
of course there is!
java
09-12-2008 05:06 AM
Hey Shane,
Hope all is well :) Like Java noted I don't think there is a faster way than using the Route Plan Report and choosing "Delete All Found Items".
Hope this helps!
Rob
09-12-2008 05:18 AM
Sounds good guys. That is manageable. I appreciate the feedback as always.
